Flappjak
I have cut down springs and the front dampers are fine and hardened up but the back dampers have lost the oil I presume due to the back end bounces a lot, so does anyone know if you can get uprated dampers on the back?
so does anyone know if you can get CHEAP uprated dampers on the back?
...only oil/gas shocks. Oil shocks without pressuized gas/ gas cussion do not extend themselves.IIdeally new ones will extend themselfs to full out position but it can take some time
generaly it is how oil shock absorber worksWell I've just checked the damper and it's easy to press down but hard to pull back up
So what should I do to help the ride then would it help if I made the front a softer ride
