With both front brakes on, this would suggest a hydraulic or pedal fault. Bit late now, but I would expect the rears to be a bit warm too. With all the clutch bleeding, might be a good idea to check the brake pedal pivot, see if it is free to move, as they share the same pivot shaft I think and they might just be objecting to all the extra movement recently.
While under there, upside down under the pedals, check that the brake light switch is not holding the brakes on. This seems to be a common issue on Stilo, search the Stilo thread for details. I think all the switches are same/similar.
Also while under there, see if you can see/feel the brake pedal free travel, to ensure it is letting go properly.
If the pedal area appears ok, another possibility could be a dead servo. When the pedal is pressed, it allows atmospheric pressure to the pedal side of the diaphragm, and with vacuum on the other side, the diaphragm helps apply the brakes. If vacuum is being applied when the pedal is at rest, it will apply the brakes.
There are various threads with a similar problem, on different vehicles. Have a wee search and see what you can find. I'm off out now, so can't do it myself.
For diagnosis, you could detach the vac pump hose from the servo and see if it then allows the brakes off. be careful where you drive though, as it will require a lot (a hell of a lot!) of pedal pressure to stop without the servo.
Edit: Why not grab a servo and master cylinder form the guy breaking one.
