johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Feb 25, 2008 #1 I have just aquired a leather steering wheel from a R reg HLX I was just wondering if anyone knew of any reason why it wouldnt fit my 2001 110JTD
JoskeJTD Patron member Joined Mar 14, 2005 Messages 1,829 Points 422 Feb 26, 2008 #2 Is it a Marea wheel? Or off a Bravo? They should fit. The airbag wont be compatible but the wheel should.
OP OP johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Feb 26, 2008 #3 Its off a R reg marea hlx
JoskeJTD Patron member Joined Mar 14, 2005 Messages 1,829 Points 422 Feb 27, 2008 #4 Should fit. Are your problems with it not going over the spline or what? In what way does it not fit?
OP OP johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Feb 27, 2008 #5 I didnt say it didnt fit I was just asking if there could be a problem e.g. airbag connection or something with there being a big difference in the age
JoskeJTD Patron member Joined Mar 14, 2005 Messages 1,829 Points 422 Feb 28, 2008 #6 You should of worded it better! Yes it'll fit the airbag connector won't but if your airbag is the same shape as the one your replacing you'll have no problems. Remember to disconnect battery for a good while and remove airbag fuse.
