Punto (Mk1)  Steering Problems
martinbusnut
Hi i have got a V reg 1.2 Fiat punto with a steering fault.
The warning light does not come on and i do not loose power steering
but the steering seems to get stuck when attempting to turn left or right and i have to use a bit of force to get the wheel to turn, As it sticks there is a grinding noise from the steering system under the dash, The fault is intermittent but getting worse,
Anyone got any ideas of cheap fix
Not sure if the car is a mk 1 or not, how do you tell the difference ?
does it look like this?
or like this?
Yes all the warning lights come on and go off again.
Car is now at M.O.T station, so fingers and all toes crossed !
Well no surprises it failed MOT.
steering problem apparently or at least for mot purpose was lower u/j pinch bolt loose and steering column universal joint insecure.
But lot of welding got to be done so its bye bye car :(
