Technical Steel Wheels Panda/Punto
FiatPanda169
Glasgow
Hello everyone
I drive a 1.1L (2009) Fiat Panda, recently the wheels have corroded to the point they’re leaking air. Wheel size 5.0Jx13”
Since Fiat do not make 5Jx13” wheels anymore I’m having to source online. I have came across a wheel off a Punto (2001) 1.2 B 44kW 3P Iron Wheel R13 -A- 5 x 13 H35 A4470201
Exact same fitting as my corroded wheels, will this be interchangeable between Panda/Punto? The only different I can think of is a different fitting on the wheel hub
Could anyone please advise if this OK? Thanks in advance
Model
Panda 169 (2009)
Year
2009
Mileage
72000
Hub and bolt pattern should be identical. Not sure about the offset/ET on the original wheels, but that's usually stamped somewhere on the inside of the wheel. I suspect they will be just fine.
Should be good (if a little old, but if not too rusty that's ok).
FIAT used the same PCD 4x98 centre bore 58.1 on loads of cars.
And offset should be the same ET35 on both Panda and Punto of those years.
I think someone bought new steel wheels in the UK from mytyres.com recently? Oponeo.com used to, but not sure what they offer in UK now.
Or Failsworth Fiat Spares might be worth a try
Thanks for the reply everyone. I bought the wheel from Italy on EBay, so I’m not too worried about the rust. More than likely I’ll be in the market again for one as the other 3 wheels are in the same condition, but I’m dealing with them as they fail
Going forward I’m just wanting to keep my wee Panda on the road, my work van does the most of my yearly mileage, I clock around 2K on the Panda. Sadly the last few MOTs they’ve mentioned the rusty rear axle, which is all too common on these cars. The front axle & engine are a lot less rusty underside
