No problem..
BUT. The coolant pump is approx 1 hours work..as you need to DRAIN THE COOLANT. AND slacken cambelt.
So IF you paid for new coolant today.. you would be adding to it tomorrow.. due to the leak ..AND.. then replacing it all again in a weeks time.
Just refill to the MAX mark today.
(If temps are staying above ZERO.. just tap water will be ok for a couple of days.. better to have fluid cooling the engine..
A head gasket failure could cost £350..)
And get it booked in for the pipe replacement.
Its your judgment on the cambelt- waterpump.
This is an identical job in the grande..and 90% of petrol FIATS..
Look around for what it has cost people
Charlie
