General Steaming/misting up
West Midlands
My rear three windows seem to steam/ mist up all the time,( ok then when driving, no funny business going on :rolleyes::rolleyes:) i just wondered if you lot used anything on your windows to stop them misting up ? if not what do you do ?
I know it seems quite a daft question and i normally just open the window a little but it normally still takes ages to clear, also only reason im asking is because when reversing its hard to see out the back.
No dampness in the boot? Small stab in the dark but are the 2 drain holes in the front bulk head clear, the ones underneath the wiper arms. The ones on the wifes car were choked solid and there was standing water in there.
Not sure about mk2b, but what setting do you have your heater on? Suck air in from outside or recirculate? Sucking air in from outside usually helps with misting.
Check for dampness in the footwells - could be heater matrix?
if it has one its under the glove box
look at the black plastic doings for the fan etc and to the right you will see a slot where it will go
only seen a pollen filter on cars with aircon mind
Thanks all. My questions have been answered. Now hopefully in the next couple of days (if it ever stops raining) I will be able to check out my Punto's misting prob. Apart from the misting prob my Punto has been a truly super little car.
