Hello,
First off, I’ve found this forum really useful; it’s helped me to get to the bottom of a few issues so cheers!
Hoping someone can assist with the current issue I’m having with my 2004 Mk2 1.2 Fiat Punto. I have been having problems getting it started. The thing is it’s really intermittent, it could start first time or it could take 20 times or not start at all. Apologies if the descriptions aren’t that clear, I’m a complete novice (got myself the Haynes manual) but have a long way to go haha. The battery is only a year old, I’ve checked the voltage which is 12.5 so don’t think there are any problems with the battery or alternator. It’s intermittent but there are a few constants though.
I took it to the local garage that hooked it up and identified an immobiliser issue. Just to note, when I turn the key without turning it over the immobiliser warning sign is displayed and remains there. I’m just confused why it ‘s worse after it’s been left for long periods, works worse in wet/cold conditions and is started every time by jump starting.
Any ideas would be much appreciated, thanks in advance!
Dan
- The problem’s worse the longer it’s left and seems to be worse in cold / wet weather.
- If it doesn’t start, jump starting from another car works 100% of the time; this is almost instant as soon as the other car is started.
- Once started, it runs absolutely fine. If I’ve got it started and drive a reasonable distance, starting it up after stopping somewhere is not a problem (generally starts first time)
- If I turn the key in the ignition without turning the car over, there is occasionally a noise which sounds like it’s coming from behind me, like something mechanical engaging up followed by a faint clunk. If I wait until this noise has stopped, the car generally starts straight away, but I don’t always notice this noise.
Dan
