G
Graham Carr
I was wondering if anyone would be able to assist me with the best way of solving a problem which has appeared on my Fiat Brava (1.4S, N Reg, 1996).
The problem is as follows:
The car starts okay when the engine is cold and it also starts okay if the engine is fully warmed up and you switch it off and straight back on, however if you leave the car for a short period (e.g. the time it takes to do some shopping, etc) and try to start it, the engine turns over but never starts. It can take up to 5 minutes of attempting to start it before it does start up correctly.
I have taken the car to two FIAT specialists, they have checked the ECU for faults but none are displayed, and therefore they have told me that they do not know what the problem could be. I have changed the HT leads, spark plugs and all filters but the problem still exists and obviously this is not an acceptable solution for me.
If anyone has experienced a similar problem and found what the solution was and/or knows what may be the cause, I would love to know.
Cheers,
Graham
Cheers,
Graham
