Technical starting prob!
shelton
leicester
:bang: ive just got my coupe bk from the body shop tryed to start it but key turns fully,then little alarm sound then nothing!! got battery power cause electric windows work,please anyone help (n)
Take the battery off and Re-charge it. Just because the windows work doesn't mean your battery isn't flat - it takes a hell of a lot of power to start a car. Also the alarm is going off because the alarm system is on the backup battery. :)
thought i would post your pm on here as it might help others :)
sammiboo said:
shelton said:
alright fella,no it does nt even try to start just alarm sound then nothing n some times the alam goes off :mad:
Hi
right, the best thing you could is take your battery off, give it a good charge and see what happens then.
it could be your start motor this takes a lot a power off the battery.
or it could be the solenoid.
Hope this helps :)
sammi
hi mate i had the same prob it does jus need a good charge but tf the alarm keeps goin of when its runnin u will have to take it of there is a little box under the passengers wing u will have to disconnect that it will still run
