Technical 1998 coupe 20v turbo le push start button
Hey guys,
Looking for part number or where to buy in UK. Im in Ozz!!. 1998 coupe 20v turbo le (limited edition) stat button identical to my picture. TIA
Brace yourself! From Fiat in 2014 the prices are horrendous! I would be looking to find an alternative.
What I don't know is how the overall push start works on the Coupe. If it is like my 500X then you have a smart key/dongle of some sort and the push button is just a simple switch.
LV4 - SPECIAL VERSION:2000 20V TURBO "LIMITED EDITION"
V7 - V:2000 TURBO MY 99
V8 - V:2000 TURBO PLUS MY 99
Thanks for the info mate. Ive been looking online with no luck. Would you call the local fiat dealer near you and see if they have or can get one. Cheers
Can only suggest you try Desira. They are normally good and I believe ship World Wide
See: https://desiraparts.com/about-us/
The will certainly need your full VIN number that way they can check for the right P/N which may have superseded the 2014 P/N:s
Since 2014 it may also be that the part is no longer available direct from Fiat. So when you speak to them make sure they give you the current P/N. You can then web search better.
