Hi, I’m looking to find out if there is a way to permanently turn off the start/stop. Currently having to turn it off every time I start driving, previous model when you turned it off it stayed off.
You could try disconnecting the battery monitor circuit.
At the battery negative terminal, you will see an in line component with one or two wires attached to it. It monitors battery charge/discharge. When the body computer thinks the battery is getting low, or cannot determine dues to loss of signal Start-Stop will stop working.
Would suggest you check that with this disconnected that the alternator is still delivering charge to the battery.
