Technical Squeling noise
East Mids
Hi guys just a quick one i was doing around 40mph and there was a loud squeling noise coming from the engine but when i slowed down the noise quietend and the oscilations slowed
Anyine know what this is?
Squealing noises are usually belts that are slipping because something that is supposed to be turning isn't or the belt is loose. Usual suspects are the alternator belt and/or bearings , the timing belt tensioner or waterpump.
My mk2 Punto made squelching noises on the drive every morning. Went away when driven. Never investigated it in the end.
Nothing but im starting to suspect its the injectors
Its the sort of whining noise when you first start your car and the pump is priming just alot louder and from the engine
But its only if i let off the throttle i noticed if i was at high speed
