Squeeking
Squeeking
M
Matt
Hi Guys (and gals),
I've noticed a funny squeek from the front right wheel area, only when I turn the steering wheel to around 45 degrees though. Almost sounds like something is rubbing. The space between squeeks decrease as I accelerate.
Any thoughts before I get Fiat to take a gander?
Matt.
Age and milage of car? Its probably the CV joint but ignore it until it starts clunking. :)
Re: Re: Squeeking
Bravo 1.6 HLX (Y)2000, with just over 20k on the clock.
Still under warrenty from the dealer so I can always take it back.
Matt.
Re: Re: Re: Squeeking
Might as well get it fixed then! :) A CV should last 70-80k though. Could always be the brake hose has come off its clip and is rubbing the tyre.
Re: Re: Re: Re: Squeeking
Hi Tom,
Is it worth taking the wheel off just to check its not the brake hose before I book it in?
Got to get them to have a look at the old gear box too, makes a lovely crunching sound (like the clutch isn't in) when changing up into 3rd.
Syncromesh perhaps?
Cheers,
Matt.
Re: Re: Re: Re: Re: Squeeking
Would be worth having a quick peek just in case.
Does it crunch just 3rd or all of them? Are the rest of the gears easy to get into?
Re: Re: Re: Re: Re: Re: Squeeking
Yup every time and only when going into 3rd, its worse if I change quickly into 3rd.
All the other gears are alright, just 3rd thats a pain.
Matt.
Re: Re: Re: Re: Re: Re: Re: Squeeking
Strange! It will certainly be a box in bits job!
You usually expect the bauk rings on 1st and 2nd to go first as they get the most abuse.
Re: Re: Re: Re: Re: Re: Re: Re: Squeeking
Thanks ever so much Tom :)
Definately a back to the dealer job then, as much as I love taking things apart ;)
Will have a look to at that wheel later though and let you know what I find.
Matt.
A
1
244
S
A
4
289
Anonymous
A
A
6
313
K
R
9
180
big al
B
K
10
252
keval
K
