Technical  Squeeking when turning
space
Yorkshire
Ok.. the car hasn't had a problem for a few weeks now so it's about time for it to cost me more money :( noticed last night that when I turn a right corner, into a junction for example, there's a slight sqeeking noise coming from the front passenger side wheel.. any advice welcome.
hi,
i have had the same problem to, for bout 3 weeks, and it is only after it had an mot and they did some think to my breaks>, it is really anoying, so i would also like to know what it is. :(
when you load up a wheel like that when corrnering the brake caliper/pad's/disk usually move about a little bit, this can cause slight noises like you describe.
if the disks and pads are still servicable you can usually fix the noise by cleaning and greasing the pad carriers and hammering the lip off the disks.
i have a similar problem, only since i had new discs and pads put on. Seems like a metal to metal sort of sound. really annoying and only happens when first start up and the first turn i make. then goes. annoys me
i have the same noise i think it may be a warped break disc rubbin
