General  Squeaking Dashboard
Tartdog
Have a 1989 (F reg) Uno 45, I think Mk 1 with a dirty brown dashboard which squeaks like bloody hell,is this a common problem?.Tartdog.
Hello, yes, brown is a common problem afflicting the base model Unos and the SX (but never the Turbo). At least it's a stylish shade of mid-brown... Did you know they came in grey originally (back in 1984) and brown was introduced later, at the time when other manufacturers were moving from brown to grey...
If it's a series-1 Uno (with the separate instrument binnacle, paddle switches, and one stalk on the steering column), most of the squeaking is probably coming from the two hooks in the bottom corners of the windscreen frame. The instrument binnacle itself, and its lid, is also a cause of squeaks. The best remedy is to take the dashboard main part out (leave the heater in place), separate all the parts (the binnacle is screwed on from underneath) and reassemble with silicone grease between surfaces that touch. Similar advice applies to the series-2 Uno introduced in 1989, except that the dashboard (still available in brown, as well as black) is a completely different design with fewer parts and the top corners are screwed in place.
To remove the dashboard main part, the basic process is to remove the switches and instruments (the lid lifts up at the side closest to the windscreen, then pull towards you), undo screws along the bottom edge (the one in the top centre under a cover is for the heater and need not be removed), remove steering column covers and undo two screws below where the instruments were, and then begin a wrestling operation to lift the dashboard hooks out of the (breakable) metal clips below the bottom corners of the windscreen. It's not really a difficult job if those hooks lift out easily (perhaps the clips are already broken and that's why it squeaks...)
Silicone grease can be hard to find (need an engineering supply shop) but it is important not to use other types of grease (e.g. rubber grease) as those will make plastics brittle.
-Alex
alexGS,
Many thanks for your reply and advice,I dont think I have the experience to tackle doing that,poss going to have to put up with it,but once again,cheers.Tartdog.
alexGS,
Another option - try some dashboard-cleaner spray :)
Spray it liberally around the top corners or around the edges of the instrument cluster - or wherever you find the squeak is coming from. Hopefully, enough will work into the gap to lubricate the plastic and eradicate the squeak.
-Alex
Could it be mice?
Removing the dashboard is easier than you think and the instrument cluster is even easier to remove, with only 2 hex-screws holding it in.
