splitting the pre-out
Cheadle, Staffordshire
ive got 2 amps in my car but only 1 pre-out on the headunit. ive split it using a few little adaptors etc but i get a high pitched buzzing which increases and decreases in pitch with the rev of the engine.
any idea how i can split the pre out properly or would i be better off getting a new head with 2 or more preouts?
yea you can get splitters that are better quality with gold plated ends ive got them on mine ive only got 2 pre-outs but running 3 outputs.
alfie
hi
u just need a RCA Ysplitter. I use em on my amps and there fine. I got 3pre outs and use one of them to power both sets of 6x9s. just pop into halfrauds or somewhere and pick em up.
and in reference to GhostWKD splitting the remote lead wont make the noise. all that lead does it tell ur amp if it should be on or off. the hum will be comin from a bad earth OR in my case, make sure ur amp casing isnt touching any bodywork or the seat, I have mine all padded and isolated now and the humming is gone.
cheers
joe
i always used to earth my amps to different points on the car, but was told its best to earth to the same point
i never had no trouble with seperate earthing points either, just make sure earthing point is clean, bare metal
didn't say it was essential just said it was a good idea
it wil clean up your signal
it will depend on what equipment your using too
halfords mutant gear won't make a blind bit of difference but higher end equipment will benefit
cheers
joe
amps arnt touching the bodywork, im gonna make sure the earths are bare metal, but i got this thing that gets rid of alternator interfierence? just incase its that
