I’m bumping this thread as I have the same question. I’ve read one other post on here where someone separated the propshaft to fit a new centre support bearing.
Anyone done it and how difficult was it to fit a new bearing?
You will need a pair of Fox wedges. They are best used interlocking to give a parallel push but you might get away with one on each side. At £15 each they are no cheap and you will need two at least.
Search "Fox Wedge" on eBay. You might find one thick enough or might need a steel strip spacer between wedge and parts you are separating.
You "can" make you own with some 1/2 inch thick steel bar and an angle grinder but it's a lot of metal to hack away from the thin end.
Big blunt chisel always works for me. Although I haven done the pandas prop. Just done some ball joints and drive shafts on an I10 and Panda and its all I used
