Speedometer...?
Speedometer...?
R
Ricky
My Speedometer...? And mileage clock are not working. Anyone know how to fix it. Ive got a bravo 1.2 w reg .
its possible that the lead has come unplugged from the gearbox. Or, its come loose behind the clocks... Failing that its likely to be an expensive fix :(
Buzz
The champion of the Bravo 1.4 & now ex owner of a Bravo 1.8
i have had my clutch replaced recently n my speedo is tempremental sometimes when you start it it is find and workin but sometimes you have to hit the dash for it 2 start working... any ideas? cheers,
Kris
Bravo 1.4s
Ricky, as Buzz said its most likely to be the speedo sensor at the gear box. reach down behind the battery tray and there is a big sensor that connects into the top of the gear box, its probably unthreaded its self, so just screw back in (pain in the bum but not to difficult, just awkward) and also check the clip connector about 3 inches up is connested. have you recently had a gearbox replacement or clutch change?
Chris (i think its chris, its one of them slade boys ;))
do the same, check at the gearbox first, failing that, whip the dials out, and where the connectors go into it, make sure they are tight, then get a sandwich bag tie (the wire wrapped in plastic) and wrap it through the connector onto the white dial backing board, theres somewhee just next to the connector that is a little loop, just do it through that and it should be sweet from there on!
Andy_sx
or it could be the bit or cog in the gearbox thats connected tot he lead as that went on my old bravo about 3-4 times!! lol
DERV POWER OOOO YEAH!!!
www.n-y-m-e.co.uk
S
1
341
S
C
4
565
Christopher Miller
C
T
1
181
S
A
260
Anonymous
A
