Re: cheers
Picked this one up from an old post but it seems relevant to some recent threads. According to my reckoning, if your wheels and tyres are about 8mm higher than they were, ie overall wheel diameter is 8mm bigger, then your speedo will under-read by something under 3 percent. In other words, if the speedo says 70mph you are really doing 72mph.
If the speedo is designed to read 5 percent optimistic (most cars do) then the effect of the big wheels actually cancels out some of the error. In other words, you can assume it's reasonably accurate now!
Word of caution, though: in general on a Bravo (or anything with 14" standard rims) the speedo under-reads by about 3.5 percent for every 10mm increase in overall wheel diameter. So if you have 17" wheels then even with low profile tyres you could be doing 70 when the speedo says 60 - outside your margin of error allowed by the plod.
Sorry if I'm trespassing on your patch Nige.
