General Speedo Probs
Nope it is an electrical driven speedo.
Take the instrument cluster off using the guide here and invstigate, perhaps a wire is loose or damaged
yes its an electrical one cause its an MPI. ill check for any loose wires.
Thanks for your comments guys!
You are looking at the sensor in the gearbox, the wiring, or the cluster.
Does the odometer still work if you drive about?
Is the PAS light on? It takes an input from the VSS so would trigger the PAS warning light I'd have thought, or at least the steering would feel very odd at different speeds as it wouldn't adjust the assistance.
Kristian
No the odometer isnt working and the power steering feels odd at high speeds because it remains light. but no the PAS light is not on...What could be the prob guys?
You can rule out anything in the cabin then pretty much. Check the senosr at the rear of the gearbox (you can get to it from the top of the bay).
Try another sensor and fix broken wiring. There is an earth line, a supply line (you can test both with a meter) and a signal line....think thats it.
Don't worry about the PAS light being off, the PAS ECU must be dumb, but your symptoms describe its not sensing the speed either.
Kristian
oo ic...ill have a look 2morrow..Thanks for the help mates. Really appreciate!
By any chance, is it that sensor which is right under the brake fluid reservoir, attached to the body? i hate these freakin sensors! lol
