I think it's the same set of ratios as the standard 5 forward speed 1000s sort of thing. it does say it's infinitly variable though ... so maybe you can get it to go up to 1/5000 revolutions....
no-one knows!!! what sort of trouble maker are you!!???..... it's questions like that, that get people like Stephen hawkins band from pub quizzes.
I looked at this thread hoping to find out what the CVT top ratio is. I read an article about the early Fiat Uno Selecta and it apparently has a wider range, and the extra flexibility is at the top end, so you effectively have a 6-speed gearbox.
My 1000S is; 1st=3.909:1 - 5th=0.831:1, so range=4.7.
The range of any CVT is: the longest-minus-shortest distance from belt to shaft centre, squared.
Square root of 4.7=2.16
So if the outside position of the belt is more than twice (>2.16x) as far from the shaft axis as the inside position, the Selecta transmission should have higher top 'gear' and lower bottom ratio.
Assuming this is true, the Selecta should be faster. If the Selecta in the Panda is similar or better than that in the older Uno, then the extra range probably out-ratios even a 5-speed gearbox both above and below.
Also, the FIRE engine has max torque at 2750rpm, and with the Selecta transmission, you can keep the engine constant around this low range whilst the CVT accelerates for you. Selecta CVT is the perfect match for the FIRE engine. My 1000S is already the best car ever, but a working Selecta would be my holy grail.
https://www.fiatforum.com/gallery/showphoto.php?photo=21727&ppuser=3776
