Speaker problems
Speaker problems
Smally
Derby
i have fitted speakers into my front doors these are powered by an amp in the boot these are jl xrs tht av components.
so my problem is my speakers work fine when the key is in the off position but then one position up and they squeal even when the volume is on 0
then when ignition is on and the volume is on 0 they get worse, and the squeal changes when i use the accelerator i dont understand y?
plz can sum1 shed sum light on my prob
toad101
just can't get enough
south east wales
you need a RF supressor, hellfrauds and car hifi retailers stock them, or try re-routing the power and earth cables on your amp.
your getting electrical interferance from the engine/alternator
chaos
Ah. Not good...
Yep, you've got alt whine - could be due to a load of reasons - bad earth, capacitance leaks into the RCA cable(s) for example.
abinger36
Have you run the RCA cables and power cables on opposit sides of the car or togeter??
