Technical Spare fuse for accessories?
EvoStevo
Established member
Northwest
Hi, does anyone know where there is a spare fuseway in the fusebox that can be used for accessories? I want to put a multi way cig lighter adapter under the dash for all the sta nav, dvr etc and would rather wire it into the fusebox than through to the battery.
if you want a constant live pull the bonnet open handle off....... remove the 1 pozzi screw (above the bonnet release)
remove plastic trim
there is a big jucy live feed black wire which unless you have a high spec model with boot fuse box is there for the taking ;-)
earth point is under the passenger side foot board trim... just under it.....
Cheers, although I think I want to put this on a permanent live and do not want to mess with going through the bulkhead (although - where can I do that?).
Where is "the existing power aux feed" ??
first pull off bonnet catch its on a square shank...
then remove this screw
then the running board by removing this screw
then pull off running board
ideally then remove the other screw holding the side trim on i just bent it out to get these pictures....
blue ring earth / -
red ring shows the thick red live with plug on the end
Hope that helps you :)
Cheers Andy, I'll try and get around to this next week, weather permitting.
I have enough inline fuse kits etc so I think I'll wire it up via a switch.
Hmm, now where to put a switch? It would be nice to have a dash one, wonder whats not used.... I need to look.
