I am in India at my father in-laws village on a long, long holiday. My wifes cousin, not knowing anything about cars payed what seems like over the odds for a MKII Uno Fire. The car has numerous problems with it, which I am trying to help him fix. I dont know much about cars but I am trying to assess whether the car is worthwhile fixing, whether it is better to sell it for anything that he can get for it or whether he should attempt to make the perilous (given the current state of the car) five hour journey to the nearest city with a FIAT dealer to have a diagnostics done.
The car has 16,000Km on it for a 1999 car......hhhmmmm. Can we improvise on any of the probs without having to get a FIAT part ?.
I'll try posting pictures in a few hours or as soon as the rains stop.
Here goes with the problems:-
1. At the front of the engine bay on the left hand side there is what looks like a small black drum with the words "fuel tank" on it. On top of this there seems to be what looks like a black screw cap with the words "Rochester Products, Control VAC 2" on it. From this screw cap there are two pipes, one black and the other blue. They connect on the thing that sits above and behind the engine and in between them on this thing is a screw (see point 3 below). So, as we look at it from from left to right, we have blue pipe - screw - black pipe. However, the "male" bit that sticks out of the thing has snapped off in the black pipe and the black pipe is just dangling there. The local mechanic said it does'nt do anything so don't worry about it.
2. Loss / lack of power
As you shift through the gears while driving from standstill: There is acceleration in 1st and 2nd but not as much as you would expect. In 3rd, the car accelerates but you have to floor the pedal. At 40km/h (any fatser and the car is liable to take off given the number of potholes in the road) in 4th, with the pedal floored the car, if you're lucky will maintain speed but loses speed most of the time. Causing you to drive in 3rd for most of the time while at this speed.
If you encounter an incline, sometimes dropping throught the gears does nothing to halt the decrease in speed until you come to the point at which the car stalls. On re-starting the car you are able to negotiate the incline in either 1st or 2nd gear. Now, thats assuming you're not rolling down (in reverse) the side of the valley at this point due to point 3 & 5 below.
3. Stalling
The vacuum advance pump(vap) seems to have gone and I have blocked the air intake with a screw as suggested in other posts (thanks to all who contributed to those). When the fix to the vap was applied the screw mentioned in point 1 above is able to affect the revs. The car still stalls on occasions but the fix did improve things dramatically
4. Breaking
The car does'nt seem to be as responsive to breaking as I would expect.
5. Hand brake
The hand brake can be pulled all the way up and it still rolls. Do you need a specific Fiat part to fix this or can a mechanic in the local town improvise?, or could we improvise with something, barring cutting a hole out and using our feet ?.
6. Oil leak
There is oil around the engine and connection with distributor(marcelli). I don't know if its simply seals that need replacing or whether there is something wrong with the head. Is taking the top half off simple enough to do for a novice like me to change any rings that need replacing. While the top is off, would I be able to tell simply by looking if there is a problem with the head ?.
I dont know if the car is losing any water or oil as journeys given the state of the car have been kept deliberately short.
7. Screaching noise
The car makes a screaching noise every now. Could this be a loose cambelt ?.
8. Poping / backfiring
It makes this noise I think when attempting to accelerate hard.
9. Other
9.1. The slider that controls the mix of air entering the cabin, between fresh at one end and recycled cabin air at the other can'nt get beyond the half way mark.
9.2. The dial that directs air to de-fog the front windscreen when selected does not in fact direct air to the windscreen. Dangerous, given that we are in the monsoon season and the fact that the roads are covered in potholes and shared between cars, people, cows, bulls, dogs and horses. I once had a stand off with a pony. The pony did'nt budge no matter how hard I revved the engine or how many times I sounded the horn. All it did was chew whateever it had in its mouth and give me the evil eye !.
9.3. The indicators and hazard have stopped working despite him fitting new lights a month ago.
Many Thanks
Danyaal
3. Stalling
4. Breaking
5. Hand brake
6. Oil leak
7. Screaching noise
9. Other
Many Thanks
Danyaal
