Sony Ericsson Xperia X10
ros07
Hi I'm thinking of upgrading to an Sony Ericsson Xperia X10 soon and was wondering if it worked with Blue & Me, i.e. calls and also text message reader.
Also, Vivaz or Satio?
Yes, the X10 works fine with the Blue and Me for phone calls but not for text reading(mine anyway). Great phone by the way but battery life poor(car charger always needed).
Can someone help me on this.
I was using one basic Sony Erricson R305 or something i dont even remember. :p
Then the Blue and Me was working totally fine. At least I was able to talk over phone while driving. But now I started using Sony Erricson W395 and its not working fine at all. I am able to connect to blue and me, but as soon as I get a call, the phone hangs. Please help me on this. Nowadays am skipping a lot of calls while driving.
Hey guys I have a problem with my x10.
pairing is working fine, but whenever i connect and b&m is trying to read the phonebook, i get disconnected, the process "com.android.phone" on the x10 gets force-closed and b&m is showing "no bluetooth" in the display.
any advice what i can do?
do u have any task killers installed on the fone??
if so disable it..
my x10 works f9.. i have never used the text message feature though..
calls and ph book work just f9..
Hi i have been using a sony ericcsson W890i which works brilliantly with Blue and Me, but recently upgraded to Xperia X10 mini. Can anyone advise me how i can get this phone to pair with my system. I enter the pairing code but my phone freezes and flashes up with a message that there is a problem with the Bluetooth. Does anyone else have this problem or any advise to help me please im desparate now to use my phone :confused: Thanks
if so disable it..
no task killers at all, they make working with android just worse. but i think something is preventing b&m from communicating with android. just don't know what it could be :( btw. i'm rooted, perhaps that's an issue?
Just a suggestion as this happened to me with a SE phone before :idea: -if you are using a portable sat nav with bluetooth enabled you should disable the bluetooth function as the problem discribed happened to me and use the B&M bluetooth instead. If this suggestion didn't work ignore me. :shakehead:
