javednazeer
- Joined
- Nov 27, 2004
- Messages
- 42
- Points
- 23
To begin -
1. Add Wynn's Engine Flush or any commercial engine flush available - Please remember that the engine needs to attain normal operating temperature while doing this. Once this product in the engine, rev it steady @ 2000 for 8 - 10 mins ( please do rev steady for the flush to do its' job )
2. Drain the oil, be carefull not to burn your hands ( wear some protective gloves) Well while the dirty oil is pouring into your oil strainer, you can remove the oil filter. Now the important bit, if you want your oil to be clean and not contaminated with the black usual diesel oil. While the oil filter is still in place, start the engine for a rough 15 secs. This will make sure that all the oil gateways are cleaned.
3. Clean the oil filter area, put some oil on the O ring to help with the tightening process and mount the sump nut too.
4. The Marea td100 takes 4.3 Litres of oil including oil filter, so we need to be precise here, too little is as bad as too much.
5. Get some Molyslip, Wynn's Supercharge for diesel and Wynn's stop leak ( what it does, it protects all your rubber hoses and seals any minor leaks which form grime after a while ) Add all this into the oil orifice. In all this 3 items makes 800 ML. Now do your caculations as you'll need 3500 ML of oil.
6. I use Mobil Super Synthetic oil - 5W 40 pure tri synthetic oil. It will give you prolong engine efficiency and high power output at all range. Well once you finish, get the oil gauge after 4 mins and give the engine a start.
7. You should notice : -
1. Quieter Engine and smooth start up
2. Better Fuel comsumption because of less friction
3. Better running temperature because of less friction, so less heat
4. Smooth power delivery across torque band
5. Excellent power maintaining and superb engine lubrication at high speeds.
6. Oil does not thicken because of oil viscosity improvers
Well I hope this does good to your engine and to your driving taste as my car has greatly improve and I must say, it eat miles while each time I open the bonnet I see the engine smiling at me. Don't forget as it is what we eat stands for us.
Don't forget to change the diesel filter and air filter during the process, they are cheap as chips.
Good luck.
Good luck.
