soaking print heads
soaking print heads
In a house
basically i have a cannon ip4000 and pritn head has become blocked on black
i went to shop to get solvent they dont stock it then she said best way is to soak it for a while is this ok its got electrical connections on the black
somthing like this just one less slot
base_media
Just stand it in water deep enough to cover the bottom of the head - a few millimetres. Even if the contacts get wet, just make sure the head is fully dry before refitting it.
After soaking, use absorbent paper towels to ensure you can 'draw' ink from the head. If you can't, soak it longer.
