Two considerations I have from the tight Scotsman is that the diesel will require more frequent servicing and fuel is more expensive.
Liam
Liam
Hellcat said:Actually diesel requires less frequent servicing.. No plugs to change, no HT leads to change. Fuel may cost a few pence more but you get double the MPG.
bloomfieldliam said:Hmm I made that assumption based on the VX Omega Diesel, needs a oil and filter every 6K where as the petrol doesn't.
Liam
JTD Monkey said:The petrol will sound nicer, but the 5-pot diesel still has a nice 'thrum' to it too. Also, the diesel will always pull at low revs so you will get brilliant performance and good economy as opposed to brillaint performance and shares is Esso...
raton_laveur said:MJTD, that the new Multi-Jet version of the JTD engine.
I wonder if the new Grande Punto is wide enough under the bonnet for the 2.4 to fit. The 2.4 is a five cylinder inline engine, so it may not be able to go in there. 200 HP and 400Nm of torque in a car that size.....Holy Hippopotamus, that would be quick!!!
Catseyes said:Your all mental.
The Diesal has more torque and more bhp, it is the faster car out of the two, it is better on fuel, has cheaper tuning potential (ie larger turbo and or more boost for a dramatic increase) and the insurance will be about 10 groups lower.
Your all crazy I tell ya for even thinking about not getting the diesal!!
Hellcat said:Although you might be able to afford the car, its insurance and the petrol.. Have you budgeted for all the things that could go wrong? You'd be gutted if your car was off the road because you needed a couple of hundred pounds worth of parts/labour.
hmallett said:You do realise that on the 20V, the cambelt is a £1300 engine-out job?
H
bulldog5046 said:MJTD??? not heard of that before?
Er, the smiley was meant to indicate that it's NOT a £1300 engine-out job (though it once was). £400 would see it done, with all tensioners replaced.bulldog5046 said:yep, getting one thats had the cambelt done![]()
hmallett said:Er, the smiley was meant to indicate that it's NOT a £1300 engine-out job (though it once was). £400 would see it done, with all tensioners replaced.
H
