"So, please, please help me..."
A
Anonymous
Yes, I need help. I am the newcomer with my secondhand Bravo 1,2-2000(MK2), and I need some answers because I do not have any manual to use it.
1.Under the steering wheel, on the left side, neear the door, there is some membrane with sign "PUSH", so I think that is probably some kind of hand pump, but I do not know what is that "thing"?
2.Yes, I also have problem with air control valve and eratic idle (2000-2500), so give me your experiences with detail procedure to disasembly and clean that valve.
3.On that car I have electrical side mirrors, but on the central position, near the handbrake, I do not have control switches, just plate with space for the coins. Under that plate I saw conector with 8 wires. I check that wires, with instrument, and at one wire I measure voltage. So, my plan is to install new switches for that side mirrors, but I do not have any wiring diagram. Please, can someone explain to me how to conect them. Also, I do not know how many positons have that mirror. Is it only left-right positions, or up-down too?
I hope that you anderstand mee, and I waiting for your answers and advises.
P.S. sorry for my incorect English
[email protected]
Hi there and welcome to the forum.
1 - That sounds like the reset button for the fuel cut-off switch. Do not worry about that. You only need to press that if you have had an accident and the fuel supply is cut off;
2 - Sorry, not had that problem but I'm sure someone can help;
3 - The mirrors go up - down and side to side. You will need a switch mechanism from another car which should have connections that will just plug into the loom.
Good luck and please post some pictures of your car and also where you are from.
"What's the word on the street Huggy Bear? ;)"
http://www.billhicks.com/ New Ozrics Site now up: - http://www.ozrics.com/
Abarth Valve Caps ;); Clear Repeaters; Supersprint cat-back;
Bonnet Lifters; Personalised High Level Brake Light; Starsky Cardigan :)
1. Could it be the lever to release the bonnet mechanism, I know mine is under there and the fuel cut-off switch is under the passenger seat.
My Member Page
He's an overseas owner so the steering wheel is on the other side chap. ;)
Thank you, for instant answering. Yes, I am from overseas, Sarajevo-Bosnia and Herzegovina, and I will try to send you some photos of my car in next period. Good luck on your wheels, buy.
Dobrodošli u odreðeni èlan Bravo forum. Ako samo naš srpski je dobar kao tvoj engleski jezik. Ukoriti odreðeni èlan izravan Translator
Conrad
Online translators are rather dodgy. Hope I haven't mortally offended you :)
Conrad
Is this any better?
Halo i dobrodošli na Najmljeni ubojica forum. E da mi može pomoæ sa bilo koji pitanje te imati. uživati tvoj zustaviti.
Regards
Conrad
That means nothing, no sense...no help with that online translator. English please.
B
2
541
Tommy K
T
3
1K
Tommy K
T
G
583
garaint
G
