So now it wont reverse....and doesn't like going forward...!?!?!
H
Homeboi
I'm hoping someone can help here. I got a P-reg 1.4sx Bravo with about 67k miles on the clock, bought second hand about a year ago. Love her to pieces but now its testing my patience.
Last November the injector light started coming on while driving - usually after she'd been over rough roads or pot holes. I'd pull over, shut the engine off and then when I started the light would go away normally. The engine sounds rougher but not too bad. I'd read about using a petrol additive to clear crap out of the engine and this has helped somewhat. She runs a little smoother and the light hasn't come on as often.
Today I took a long trip on the motor way. Fine, no problems. Then I pulled into a small carpark at a local park. I tried to reverse into a parking space on a slight incline. Couple of inches moved, injector light comes on and engine dies. Tried a couple of times and same thing. Almost like stalling when pulling off without enough power (even with my foot nearly to the floor). Then the engine wont start at all. A fella helps push it out and says it sounds flooded (not very good with mechanical things so I believe him!!) Give it a few moments and then she's able to start (going forwards). Not happy, but mobile all the same.
Then I get near to home. Turn left off a main road into a side road and she dies mid way around. Fortunately I'm able to coast up the road a little. Try to restart. She ain't havin it!! Had to wait twenty minutes before I could restart her (and she died again a little further on) to do the rest of the 4 minute journey.
She needs a new exhaust, think the clutch is going and I'm sure the rear shocks want replacing too. But can anyone suggest what else could be wrong. Any an all suggestions welcomed. Love the car and don't want to get rid, but if she's gonna start playing around like this...
Definitely sounds electrical. I've had a few cars that did a similar thing and it was always something silly. If the injector light keeps coming on you'll need to suck it up and take it to FIAT for a diagnostic to find out what's wrong. :(
Shabash!
Injector light coming on means there is a reasonably serious problem and they don't generally go away. Take it to fiat.
Re: Re: So now it wont reverse....and doesn't like going forward...!?!?!
I was afraid you were gonna say that. Think this is gonna be an expensive easter!
Re: Re: Re: So now it wont reverse....and doesn't like going forward...!?!?!
I had a problem a while ago that was similar in some respects.
Basically I could be driving along and the engine would be fine. Then ocasionally when trying to pull away from traffic lights etc, the enigne would just die and the injector warning light would come on. If i left it for a short while It would generally restart and run ok for a while or sometimes it could take longer and the engine wouldn't even turn over properly!
After a fiat garage had a look at it, I was told that the problem was an 'RPM Sensor' which was faulty.
Once it was replaced though the problem didn't occur again!
Re: Re: Re: Re: So now it wont reverse....and doesn't like going forward...!?!?!
Thanks for this, it sounds very similar and I'll bear it in mind. Out of curiosity, how much did it all cost?
I've got it booked in for an ECU reading on Thursday. Just hope I can get it there without it dying!! I'll let you know how she gets on.
Re: Re: Re: Re: Re: So now it wont reverse....and doesn't like going forward...!?!?!
Couldn't tell you how much it would have Cost as it was done under warranty due to other repairs that the Fiat garage had undertaken with the enigne at the time!
same problem
I have a similar problem with a Marea. There is no pulling power over 3000rpm, although when in neutral, it'll rev quite happily.
Did you resolve the problem with the rev monitor??
JimY
J
1
769
Dark Lurker
505
Dark Lurker
A
573
anthony jenkinson
A
J
2
270
Dark Lurker
T
4
409
A
