KY Jelly, or Durex Tingle?
It's that time of year again, the sun is out so the skyroof is playing up!
It all worked just fine last year, but this year it's playing up. The problem seems to lie with the front glass panel sticking on the o/s. When you turn the switch, the nearside opens about half an inch, there's a lovely grating noise from the motor and the whole thing just gives up. However, give the sticky part a good shove at the right time and it opens up just fine. Likewise when you try to close it, it gets so far, stops the motor makes the grating noise and it won't quite close. Use the reset while leaning on the the front glass panel and it closes! Sounds to me like it just needs a thorough clean.
So, what do ya'll recommend as a good lube? I've no idea what is currently on it, but in parts it seems to have crystalised, while most of it seems to have somehow become watered down. With luck the weather will stay decent this weekend so I can de-grease, clean up and re lubricate the skyroof, I just want to make sure I get something decent to put on there. All suggestions welcome.
