Skipping albums
Skipping albums
Cymru
Hi all!
Got a 63 plate fiat punto easy with blue&me. Just put a USB stick in and everything starts playing fine and can skip tracks etc. I can't however find a way to skip albums (they are all in folders), pressed up arrows and numbers etc. is this normal or can I fix this!'
Can anyone help? It also doesn't appear to play all the songs on the usb stick. Is there a file format it needs to be and a specific directory structure?
Try to label the folders 1,2,3 ect
Make sure the mp3 files are not a mix of any other format like wma
A good quality mp3 is a must 320 kps is the best
Also if you burn your files to disc and then transfer to your stick/sd card burn the disc at a slow speed as a fast burn can leave out information leaving you with bad quality copy.
LUIGI
Yes thats it, do ''01'' ''02'' ''03''
This really is a test, there may be an issue id tagging, ie, your album titles can't be read, but any mp3 player or what ever should be able to read 01,02,03 ect
LUIGI
