Technical siecento engine management problem
moorcky87
hi all i need help!!!
iv got a 2001 seicento which i bought as a non runner, iv put a new ecu on it new coil packs and it now runs, but slightly lumpy on tick over and with the engine management light on, when i plug it into computer it brings up the code P1325, which i believe is related to the knock sensor which i have also replaced, which has had no effect. i have now no idea what else to check, any help or idea would be much appreciated
cheers
how much have you run the engine?
is the battery fully charged?
the battery is also new, i haven't run it that much i have had it up to running temperature on a few occasions, but thats about it.
Try re-setting the ECU. Also, check the wiring to the knock sensor.
i have reset the ecu, still get EML comin on, i think it may be a wiring fault although there are no signs of damage to any wires, i think i may put another loom in it and pray, cheers
Siecento Engine Management Light
Not sure if you can help but I have a Y reg Siecento and the Engine Management Light comes on from time to time where sometimes it stays on and sometimes in flickers/flashes.
Any thoughts?
