Technical  Side lights
djstew
Kent
With headlights off only one side light is on. Get yellow warning light.
Turn headlights on and both side lights come on. So not the bulb.
Wondering if this is likely to be a simple wiring/connector issue or something more complicated?
Regards
David
New bulb type 580 and all will be fixed, can be easier to remove the wheel, note its often a good idea to cable tie the hatch in the inner wing guard in place by drilling holes in it, also firmly attach the rubber cover on the rear of the light cluster, can be easier to turn the holder with the wrong hand or a spanner
