lamboboss67
- Joined
- Jan 30, 2013
- Messages
- 28
- Points
- 11
Hi again. I have a 2007 Grande Punto. I mentioned this issue on the forum before but didn't get many responses so I figured I'd raise it again seeing as it is a major nuisance at the point. Airbag warning light is permanent (the red one not yellow one) and mechanic says the code is for the side impact sensor. I believe it's the drivers side. Sensor is located in the B pillar behind seatbelt. We have tried about 4 used sensors so far and none of them have solved the issue. He is now testing the wiring with multimeter. Can't get the car to pass the r/w test without fixing this:bang: Now I did have the power steering module replaced just a few days before the fault came up in the first place, so I thought it could have had something to do with meddling with the front driver's airbag during steering module replacement. But now that I know the fault code is for the side impact sensor and not the front impact sensor (which is a completely different circuit to the side airbags) I don't see any causation. Does anyone have any ideas as to what this could be? Had the problem for nearly a year now. Here is a picture of the exact type of sensor this is.
