Technical should something be connected to this.. ?
smokeymacpot
car is a 1.2 16v and it like "holds back" when accelerating, eg over 3000rpm with foot to the floor it just doesnt pull as hard as it should do :confused: so i was looking for broken vacuum pipes and saw this and wondered if a pipe should be connected to it? what is it ?
http://postimg.org/image/w8a1oxu0d/
ahh i just took it to bits and its like a blank connector for the blue wire thats probably not in use on my model of engine.
no never had any warning lights ever. battery disconnect doesnt help.
can i clean the map sensor or stepper motor?
what should the plug gaps be for this engine?
If you have the fly by wire throttle body it could be the stepper motor or the pedal sensor if you have the one with a proper throttle cable the stepper motor wont be the cause since it only controlls the rpm up to something like 2000.
The plugs are already pre-gapped. Just change them for the small price, they should be changed once a year anyway.
Id try a scrap yard coil pack or test it using a voltmeter. Heres the test:
Id also try cleaning as many electrical contacts, plugs and earth points as I could with some electrical contac cleaner. Including the flue pump ones in the boot.
