Technical Should I replace my coil packs?
fiatmultiair
Serbia
Hello,
Hope you all are having a great morning!
My 1.4 Turbo Multiair has its original coil packs from 2009, should I replace these? Car for the most part is running fine on idle it does shake the cabin a little bit but over all that's normal for these engines. Car has around 210K kilometers.
Personally,
I would buy 1 OR 2,
And swap to #1 and #2 positions with your new spark plugs,
Unless there are differences in Plug Colour, showing a poor running cylinder, then fit a New coil Pack there🤔
210,000kms
Pretty good 👍
Have you done your own servicing?
I don't have any codes or any issues starting the car, I just seen online that people change these after like 100K miles or every 5 years so I wanted to ask if this is a run until broken kind of thing or I should replace them since they are the original ones from 2009 and my car has 210K KM. Color of the coils are fine, and they are in okay shape did not see much of them being used up.
I just changed the spark plugs and I'm seeing better gas mileage, fixed the strange noises from my engine bay by changing the alternator, belts look okay nothing is torn or signs or it being crumbly/dry.
So, what I'm getting is if not broken don't fix it?
