DJ Overdose
Well my B had it's first service since I have had it.
All in all a very positive outcome. As my GF's brother in law works for a Fiat garage, it only cost me £130, and I got to drive his car about while he did it.
Although nothing serious he did raise a few points.
1) Passenger side head light mists up, possibly due to mis-fit of seals when bulb was last changed.
2) Rear passenger side brake disc has red rust edges, yet drivers side has normal black brake dust/rust on. Said this is because passenger side is running hotter. Car not pulling to one side so, not an issue at the moment.
3) Roof leaking somewhere... Puddle in one of the wells under passenger seat. Concern was corrosion to seat brackets caused by condensation and evaporation of water. Getting a hood guy to look at replacing hood, but may check to see if I can find leak first.
I know leaks in all soft tops are common, but there are a few places where it could be coming in, that a new roof may not fix. Bloody window rubbers on, yep, passenger side... On part of one of them kind of folds inwards, you will need a pic to understand (will post later). Also water could be getting in under the hood where it meets the back of the car, on passenger side.
As I said nothing major, and a very cheap service. I'm pretty chuffed considering my B was one of the first made... ;-)
DJ OD
DJ OD
