Technical seicento hub
shnowzy
lancashire, United Kingdom.
i just replaced my driveshaft and when ordering new part they say it could be one of 2 driveshafts as it is a 2001 model (change-over year)
now i realised my problem is the front wheel hub
does anyone know if these changed also that year as i found a t reg car in scrappy with hub on would this fit my 2001 year car ?
or will any other fiat hub fit this car ie punto brava ect??
thanks
You know, I don't think the hub changed. Certainly the inboard parts of the driveshaft are different on the Sportings and the non Sporting 1100: depends on whether the gearbox oil seal is dry (Sporting) or wet (the boot forms part of the seal and is full of gear oil). The gearboxes themselves are different, so you can't fit one type of shaft onto the other.
Anyway, check in ePer. But what makes you think it's the hub?
