Technical  Sei Reverse Problems....
By-the-sea, Norfolk, UK
Hi, at the moment I seem to be having problems getting reverse gear, sometimes it crunches and sometimes it slots in perfectly.
I've recently had a new clutch and gearbox oil. I have adjusted the clutch so I can now select first without it being stiff and notchy but I still get random occasions where I cant get reverse no matter how many times I try, it just crunches... :confused:
Anybody know what might be causing this?
Thanks,
Ben
Thanks,
Ben
Would have said clutch, next would have been adjustment, 3rd syncro... Is it the correct oil grade? Does it do it from both hot & cold?
It almost always does it when hot but still occasionally if its cold. Sometimes if I park up and come back to its about 10 minutes later its ok again, can reverse out of parking space etc.
The other day I put it in first and jolted the car forward a meter or so then it slotted into reverse perfectly.. however I cant get it to do that again, probably a coincidence...
....I've recently had a new clutch and gearbox oil. I have adjusted the clutch so I can now select first without it being stiff and notchy ....
Re-adjust the clutch AS PER the manual, then re-check it after everything has had time to bed in.
There's a manual you can download on this site.
To save you going through the entire manual (it's a right pain in the ar*e
to negotiate)....
Push the clutch pedal right down & measure the distance from the floor to the pedal, when the pedal is released it should be 120mm (+/-5mm) higher than when it was fully down.
Hi
Think that is normal, mine is difficult, if you are starting from cold the increased engine speed (at tick over) will baulk reverse selection, park overnight for a forward drive out.
Counting 1,2,3 slowly (as above) is all you can do normally when it should select, some of the time, without a 'crunch', dont bip the throttle before you do this, it needs to be done from a slow tick over.
Or start in reverse with hand brake and foot brake applied and clutch depressed.
I'd take time with 1st and 2nd selection as well, and the box needs the full synthetic, or rather mine does...
Noel
Well I've adjusted the clutch this morning, the biting point is now a little higher and the clutch pedal sits at almost exactly the same height as the brake pedal. It also has around 120mm of travel.
I will have to wait until Christmas day until I find out if it has worked as I will being having a longer drive to go and visit the relatives.
This has made me notice how despite the revs being fine it is very lumpy at idle and it rattles like a tractor but anything above about 1000rpm its perfectly smooth....
There's also a very slight hissing noise coming from the left side of the engine, cant pin point where exactly its coming from... might be the expansion bottle cap? :confused:
Hi
Stethoscope the alternator and tension-er, wait until the warm weather if you don't have a warm lock up. Find a real engineering shop to recon alternator, or do a WTB in (this) site(s) shop, (and sell on your alternator). If you remove the top belt cover, (easy) and the non tooth side of the belt is scuffed, you may need to address immediately.
Both the alt and belt tensioner should last to spring otherwise.
You need to remove the front wheel, inner arch, and (you need to) read the guide on alternator replacement, once you have the inner arch off, replace the tensioner, belt and water pump, anyway, as they don't cost a lot, don't use a pump with a plastic impeller..., there are three pump impellers, cast OEM, plastic OEM and 3rd party machined, plastic has an additional fail mechanism...
Noel
