kemo
Hi all
i drive a 2.0lt 20valve marea great car has everything i need in a car factory fit alarm ect. just fitted the best imobilizer any one can fit at the cost of £2.00 ( if you dont smoke like i do waste of time having a lighter in the car so make use of it) all i did was cut the main wire under the dash and wire it into the lighter make sure it is not going to earth go to car shop and buy a plug the sort you get on inspection lamps unscrew it and solder a wire to join the live and earth together push it in to lighter and hey you have power to motor pull it out and no power. most alarms are ok but if you know what you are doing you can over ride them how many car do you see without a cig lighter no one even thinks about it
