General Seals
General Seals
digger58
Established member
Limerick
Has anybody found seals for the clutch/brake master cylinders and the clutch slave cylinder? Would be interested to try some, thanks,T
The slave cylinder can have quite a rough life with rain/salt/grit from the road, so chances are the bore & piston maybe too far gone to be worth the hassle of replacing just the seals - normal recommendation would be to fit new. It pays to shop around though, as a reasonable price one can be found (they can vary greatly in €£$ for exactly the same part :(). For the master cylinders, then the bores should be better, but can still score, so for piece of mind (and potential minimum agro in re-fitting sooner than you would wish), whole units are most peoples chioce.
Thanks for that folks, I have a Sykes/Pickavant hone for brake and clutch master/slave cylinders seems a shame to waste it, my clutch slave is weeping at the moment so was goint to try and get a new set of seals, any other ideas? thanks in advance, Tony
