General Scanner
General Scanner
ninian324
Hi, What is the best scanner suitable for my 2014 Ducato. I'm just looking for something that I can use without the use of a computer in case I ever need it.
Thanks.
MultiEcuScan won't be suitable then, unless you have an Apple iPhone/iPad and I have no idea whether the "i" version is as good as the Windows application.
AlfaOBD is a similarly powerful diagnostic tool and runs on Android or Windows devices. It can be found on the Google Play Store for Android. Unfortunately unless you go with a PC or a dedicated diagnostic machine, you are restricted to bluetooth or wireless communication with the vehicle.
If you go with AlfaOBD though, you will need a decent bluetooth OBD adapter such as the OBDlink MX+ or OBDkey devices, as cheap Chinese ELM clones often don't work with the adapter cables in my experience, and you will need at least the yellow MulitEcuScan adapter cable to connect to some ECUs.
The cables can be bought from Gendan.co.uk and aren't expensive.
There's a lot more info at AlfaOBD.com
