- Joined
- May 10, 2010
- Messages
- 2,669
- Points
- 799
The most common causes of the code P0101 are:
Dirty, obstructed or faulty mass air flow sensor (MAF)
Cracked, ripped or disconnected intake boot (snorkel)
Vacuum leaks (from stuck open PCV valve, leaking intake gaskets, etc.)
Clogged up or improperly installed air filter
The mass air flow sensor element contaminated by excess oil from an oil-soaked air filter
Clogged-up catalytic converter or restricted exhaust
Other possible causes include:
Dirty throttle body
Bad or dirty manifold absolute pressure sensor (MAP)
Electrical problems with the MAF sensor connector or wiring
Stuck open EGR valve
Incorrect valve timing
faulty engine computer (ECM)
Seeing as you've already had an egr code, start there.
Dirty throttle body
