Hi Guys
The wife has a 500, 14 plate. The other night she went on a small round trip (4 miles) and when she got home she told me she had lights come up on the dash. She's adamant the lights came on for no apparent reason. The car seems to drive like normal even though all the lights are on.
The symptoms are:
* Main Airbag light on
* Passenger Airbag light on
* Seatbelt Light on
* General Fault Light on (Yellow triangle with exclamation)
* Odometer displays, "Fuel cut-out unavailable"
* Millage is flashing
Things I have tried so far:
* Read for fault codes with Mobile app “Torque” – None stored
* Checked cables under the seats – Nothing obviously disconnected.
* Indicator trick, (right, left, right, left) to try override the fuel cut-out – No affect at all.
* Service reset (accelerator pedal down 3 times)
* Disconnected Battery for an hour – No affect
* Looked for Airbag Relays in the fuse box, but couldn’t find any.
* Called the dealer who advised its £90 for a diagnostic and couldn’t offer any help otherwise.
I came across some posts which explain that flashing millage is an indication proxy alignment is required. From this I suspect some sort of safety module must have crapped out (potentially the airbag). I researched the proxi alignment procedure. As luck were to have it, I have MultiECUScan2.2 through issues with electric steering on the wife’s previous punto.
So I connected the car up to MultiECUScan and 1st checked what I could connect to. Engine, ABS fine but I was unable to connect to airbags. This makes sense and also ties in with the theory of “proxy alignment” being required – On the airbag module perhaps?.
I proceeded to try run the proxy alignment, but if fails with “Unreliable communication detected”. This is 100% the elm interface I’m trying to use. So, the investigation took a new turn.
I came across posts where guys reported removing a resistor sorts the issue. Unfortunately, my Elm tool is not the same board and of different shape. I’m also not convinced that buying the latest version of MultiECUScan will fix the communication issue. And with the amount of fake Chinese Elms on eBay, I feel it would be a lottery as to whether or not ill find a working one.
So ..... For now I’m stuck, but decided to come on here to ask if anyone knows anything I could try, or whether anyone is able to help me fix this?
As a last resort, im going to jump the car with mine, to see if its potentially a weak battery issue, but i feel im clutching at straws
Appreciate any help you guys can afford to offer.
Thanks!!
The symptoms are:
* Seatbelt Light on
Thanks!!
