Technical run wire through bulkhead
No, but it's on here somewhere. From memory, there are 3 the same, one is indicators, one is headlamps, one is the horn. You could pull them one at a time, see what doesn't work, label them, swap around, etc.
See the headlamps, is that for Full beam ? i.e. the one you can turn on temporary by pulling the level ?
As that doesn't work either lol!
Ming
So after i took out the sound proofing on mine, i again found no hole where the speedo cable should go, I did make a hole for my wiring though, just another question, does anyone know what the last replay and fuse on the left of the fuse box are for?
They look like they are extra's but every cinq i have seen at looms has them.
Here is a picture of my bulkhead
