first time posting in the tech side of this forum so im not sure if this is in the right place,
okay, ive seen somewhere online these special bolts that you use for connecting another hose to a intake pipe, water and oil pipes.
what you do is drill a hole into the main pipe, put the bolt through the hole and tighten up the nut on the other side of the pipe. The bolt has a hole down the center and on the threaded end of the bolt you connect the second pipe to it.
what are these pipe fittings called?
