Technical  Right mirror
skazo4nik
Raplaced right mirror by new one. And get a trouble. When I trun rear, mirror comes down. And when I change to first gear, mirror comes up at maximum value, ad shows sky to me. Tried to fix with elm, but don't find anything about it... Is there any calibration mechanism? Can I set default position? Programming to seats mem don't help.
Did you replace it with the correct mirror? If you have electric seats, you need a memory mirror, not a normal one.
If you have electric seats and memory mirrors, the passenger side mirror is designed to point down to the kerb when you select reverse.
To stop the mirror pointing up to the sky, adjust it with the normal mirror adjuster, then press and hold one of the 3 seat memory buttons until you hear the beep.
I tried to save position, it doesn't help... It seems I need to try to assemble one normal mirror from broken and wrong mirror...
