Technical Retro fitting front fogs
Lincoln
Hi
I am planning on fitting front fogs to my 2012 Easy. The car didn't come with them so I'm wondering if anyone has done this and how difficult/easy it is.
I will be buying the bits from Fiat as I don't think there will be many in the scrap yards!
Any help will be appreciated.
TIA
Hi
TIA
have a good search of the grande punto section theres plenty in there to go on my wiring digram will help
https://www.fiatforum.com/grande-punto/151369-fog-lamp.html?p=1598765
a couple of things to conceder the DRL's should be off when the fogs are on... as per the regs (not hard to turn them off in the multi function menu)
and you will not get the cornering light system to work that would probably need a new body computer, loom and other bits...
Also you wont be able to fit a standard fiat switch as its a soft touch unit linked to the body computer
now double check but i think the evo fog lights are the same
http://www.shop4parts.co.uk/?name=store&op=Results&category=15&secondary=106&opts=3385
same for the bumper blanks
http://www.shop4parts.co.uk/?name=store&op=Results&category=24&secondary=76&opts=3385
BUT CHECK FIRST if they are wrong shop4parts should be able to order you them in
if you Donate to the forum you can save 10% on orders from them (shop4parts) via our members offers section discount code but it excludes special order parts :)
